Re: 1466 injection pump
Posted by Moline_guy on May 13, 2010 at 19:00:09 from (216.106.216.65):
In Reply to: Re: 1466 injection pump posted by bgreer on May 12, 2010 at 17:51:08:
Thanks for the information, if the lines are matched under the pump cover and the flywheel is at 18 degrees it should be on time? As far as i know they just pulled the pump off of a 1566 because they didnt have any more from a 1466, hopefully it is right, I probably should have just had this one rebuilt, but time will not allow for it right now. Thanks again for the help.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
