Adding rearend oil to 560
Posted by matthies on May 14, 2010 at 05:45:44 from (164.119.51.40):
Where's the fill hole for the rear end, drained it to check oil and can't find where to put it back in. Is the check plug in front of the clutch pedal? Do you use the small cover with three bolts by the shift lever? thanks chris
