Re: carb problems on Farmall M
Posted by rustyfarmall on May 14, 2010 at 05:50:08 from (209.152.78.140):
In Reply to: carb problems on Farmall M posted by Allan In NE on May 13, 2010 at 17:50:04:
Allan In NE said: (quoted from post at 17:50:04 05/13/10) There's something about the Hs and Ms, they just don't like that choke.
I always start mine about 2/3 throttle without the choke. After it pops off, if it tries to stutter and cough, then and only then do I give it a small amout of choke just to clean it up.
If I try to start 'em using the choke initially, they won't even start unless it is down around zero or below.
Allan
Yes, that is exactly the same procedure I use. During EXTREME cold weather, I may have to pull the choke to get it to fire, but I only pull the choke AFTER attempting to start without it.
