Re: 1939 FARMALL A STEERING PROBLEM
Posted by Rootsy on May 14, 2010 at 06:47:07 from (24.247.111.162):
In Reply to: 1939 FARMALL A STEERING PROBLEM posted by El Toro on May 13, 2010 at 14:13:45:
In a ball bearing there should be ZERO axial movement between inner and outer race.... Should be very little to no radial movement either... If there is the bearings are junk...
As I've said before, in the case of my Super A the bearing on the sector shaft was bad as stated in the first paragraph. When you turned the wheel the sector gear and shaft would raise before turning.. You could see it plain as day. The tie-rods and pitman arm would move vertically before beginning to turn.
There isn't much that can go kaput in there but what does cause a lot of play...
