Posted by glennster on May 14, 2010 at 08:07:33 from (75.57.131.175):
In Reply to: H narrow front posted by norman noble on May 13, 2010 at 18:31:04:
give it a good looking over before you throw parts at it. first, check for a bent rim. get a 2x6 about a foot long or so and drive one frnt wheel up on it so the other spins. check for wobble or out of round. then do the other one. next, check the steering shaft from the steering wheel down to the bolster for excessive loose u- joints. then pull the cover off the top of the bolster and check the worm and sector gears for excessive wear. also check the bearing on the end of the steering shaft. you remove the end pipe plug to see it. from there, jack the front end up and shake the wheels side to side and look for worn bolster bushings. carter and gruenenwald has a complete rebuild kit for the bolster for about 150 dollars. yt here has new gears for the bolster too. if you gear is a full circle and not a half gear, you can remove it and turn it 180 degrees to get some better teeth.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
