Farmall H oil Pressure
Posted by Farmall Flunkie on May 29, 2000 at 19:47:35 from (24.213.54.48):
Oil pressure good when tractor first starts after it runs for a while and heats up oil pressure falls to about 10-15 PSI whats the problem? The Oil Pump. I didnt replace the cam bearings is that it? If so why would cam berings cause it to run low Pressure.
how do you tell if the Pump is shot? thanks for the help!
Post A Followup
: Re: Farmall H oil Pressure
