As far as I know the grill is original. It had rust holes in the bottom part that I had to repair. When I got it, it had a screen on the outside, attached with sheet metal screws. I think that was an add on. I've seen a number of U-2 power units like this one and the service manual I have shows exactly like this one. I think the ones with the screen mesh grills may be U-1 units which have the Cub or a Continental engine. The U-2 uses the A engine. I don't know what this one was used for. It has a 6 groove Vee belt pulley on it which is direct drive at engine speed: 1800 RPM. There is an overcenter clutch that has a hand lever. I suspect it was on a water pump, or generator, or something like that. The manual I have shows that angle drives with gear reductions with flat belt pulleys were available. Since it was built in 1944, I doubt it came from a farm application.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
