Re: Fast Hitch 2 row cultivator
Posted by farmallhal on May 15, 2010 at 07:36:59 from (76.3.54.75):
In Reply to: Fast Hitch 2 row cultivator posted by Cmore on May 15, 2010 at 06:48:08:
They made a model 254-A for the Super C in 953 and 1954 which would also work on the 200 tractors. I don't know what might have been made later as my source (Fast Hitch Implements for Supe C tractors - FCI-2) was printed in 1955. The 254-A appears to be a tool bar type with various components to adapt it to many different uses. If you have specific crops or needs my email is open and I'll look up what is available for whatever you intend to use the implement for to see what might have been offered. Hope this helps, Hal
