Re: Moldboard plows
Posted by gene b on May 29, 2000 at 21:21:08 from (63.15.137.27):
In Reply to: Moldboard plows posted by bronco on May 28, 2000 at 19:46:45:
the cub hooks different the one i have for a SA the drawbar is reversed turned forward and the beam hooks on the drawbar the lift arm on the rockshaft goes back to a brace type that mounts on the rear fenders the arms off this brace hooh to chains that lift up the bottom when the rockshaft is moved forward dont know the number of the plow but have most of the pieces also have some pics somewhere of one on a tractor can send them next tues when i get back home leaving for CANADA IN 1 hour
Post A Followup
: Re: Re: Moldboard plows
