Re: Fuel Pump for 1951 Farmall Model H?
Posted by rustred on May 15, 2010 at 08:24:51 from (74.198.148.45):
In Reply to: Fuel Pump for 1951 Farmall Model H? posted by Ron Olsberg on May 15, 2010 at 07:48:00:
i dont believe that it is nesessary.to install a fuel pump. need to check for fuel flow first. when you undo line at carb you should have a good steady full stream running out of line , with valve open. also check the screen in the brass fitting at carb, by unscrewing and blowing out with air. if flow is poor unscrew sediment bowl from tank and remove bowl from fitting and blow out or soak in carb cleaner as the holes like to get plugged up not alowing enough gas to flow out. check your tank also for rust or corrostion.this engine is not big enough to us up the gas that fast. the W9s had a fuel pump to prevent starving for fuel when working flat out, but thats a big engine to rely on gravity feed.you could be due for a carb job also.
