Re: Fuel Pump for 1951 Farmall Model H?
Posted by rustyfarmall on May 15, 2010 at 08:28:24 from (209.152.78.140):
In Reply to: Fuel Pump for 1951 Farmall Model H? posted by Ron Olsberg on May 15, 2010 at 07:48:00:
Ron Olsberg said: (quoted from post at 07:48:00 05/15/10) My 1951 Farmall Model H has been converted to 12 volts. When I try to push snow on an uphill grade, I do not get enough fuel to keep the engine running. I think a 12V fuel pump might solve this problem. Has anyone added a fuel pump to a similar tractor? If so any advice would be greatly appreciated.
Regards, Ron
I've had my H on grades so steep that I had to hold tight to the steering wheel to keep from falling off backwards, and the engine never did starve for fuel.
Your fuel tank is either low on fuel, or there is something foreign floating around in the tank that covers the fuel inlet when going up a hill.
