Re: Identify and purchase bearing and seal help?
Posted by Ron Olsberg on May 15, 2010 at 08:29:08 from (76.18.64.119):
In Reply to: Re: Identify and purchase bearing and seal help? posted by rustyfarmall on May 15, 2010 at 08:16:42:
Thanks for the post reply Rustyfarmall
Your post indicates [No Email], looks like you don't currently accept emails from Forum members?
I am sure I will need the spinning shaft bearing because it has considerable play but it is possible I might not need the seal for the counter rotating bearing. Any ideas where I might get the bearings? Can you help me with the bearing part numbers?
Again, Thanks Very Much
Ron
