Re: Super A Hydraulic pump
Posted by gene bender on May 15, 2010 at 10:57:41 from (67.55.226.67):
In Reply to: Super A Hydraulic pump posted by FiremanKyle on May 15, 2010 at 09:57:14:
Yes by all means you can run the engine but you better cover the hole as oil will flow out the place where the pump was.
