Re: Cub hp question
Posted by gene bender on May 15, 2010 at 11:03:05 from (67.55.226.67):
In Reply to: Cub hp question posted by Chris Klein on May 15, 2010 at 09:09:32:
First thing is check that you are running rated RPMs. They are great for mowing lawns in low gear and not cutting high grass keeping blades sharp will help a bunch. Now if you want to bore the block and go to larger pistons you can gain a few HP but theres not a lot can be done with a 60cu in engine.
