Re: IH 350 New Purchase....Questions
Posted by Al from ME on May 16, 2010 at 03:28:14 from (68.171.231.16):
In Reply to: IH 350 New Purchase....Questions posted by MCL on May 15, 2010 at 17:13:37:
Tom is correct in some models having a seasonal disconnect. I myself purchased a SMTA thinking that the PTO didn"t work, but found out after getting it home it had been taken out of gear. The disconnect lever is underneath below the transmission. Its a lever about 4 inches long and 1 inch wide with two holes on one end. Simply take out the bolt on the end that has two holes and move the lever to one of the two threaded positions threaded in the casting of the transmission case to switch from engaged to disconnect. If the lever doesn"t want to engage fully you have to release the pto lever to release the pro brake bands and turn the pro shaft with a punch in the hole that"s on the end of the shaft to align the internal splines. Then the lever will fully engage. Hope its that simple for you. Like it was for Me. Most farmers would disengage them so if not in use. When engaged the bands are noisy. Good luck!
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
