Re: 49 Farmall Cub heating
Posted by mkirsch on May 16, 2010 at 04:37:49 from (67.253.216.24):
In Reply to: 49 Farmall Cub heating posted by Icuby on May 15, 2010 at 05:52:43:
Usually pressure caps are designed wrong for a Cub radiator, and won't seal anyway.
If you fill the radiator right to the top, the Cub will throw water even if nothing is wrong. Let it seek it's own level.
After you let it cool, shine a light down in the radiator neck. If you can see that the fluid level is above the fins in the radiator, it's fine.
