Re: distributor
Posted by gene bender on May 16, 2010 at 08:45:55 from (67.55.226.67):
In Reply to: distributor posted by J Thomas on May 16, 2010 at 08:39:04:
If you are rebuilding the tractor doing the dist shouldnt be hard. Didnt the tractor run when you started that would mean it does work. You should be able to replace the bushings and clean the rest up to make it like new.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
