Posted by Janicholson on May 16, 2010 at 12:23:41 from (64.61.211.125):
In Reply to: m live hydrulics posted by abartholomew on May 14, 2010 at 22:06:09:
The serial Number split is 228082 and up have the correct bolt pattern and better gears for a IH OEM pump. The older tractors can (and often do) have cam gear failures when used with the pump. The best gears are from 400 and 450s. They are stout. The front casting needs to come off and the radiator removed to replace the front cover if your serial is lower. It is a mid 1950 number. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
