Re: h-hyd.question
Posted by Janicholson on May 16, 2010 at 12:51:50 from (64.61.211.125):
In Reply to: h-hyd.question posted by joemama on May 15, 2010 at 04:05:38:
third party image
The diagram will do it. If you need two valves, one that is one way and one two way, the second valve must be connected to the return line from the first valve. The second valves return then goes as shown (if you only use a two way, or the return is plumbed into a "T" in the drain at the bottom of the reservoir. If two valves are used, they cannot be operated at the same time, but work well. Jim
