Re: 400,450 differences
Posted by pete 23 on May 16, 2010 at 18:58:36 from (173.87.144.56):
In Reply to: 400,450 differences posted by DK44H on May 16, 2010 at 18:22:44:
Not a lot, starter push button switch seperate from igniton switch , some refinements in hydraulic system like short hose near pump instead of straight steel lines, on gas tractors, late model 450 went to 12 volts, all diesels were of course 12 volt. Steering wheel if memory serves me. Fast hitch may be different depending on age of 400. Steering worm shaft on power steering model, went to a short one with splined end.
