Re: Size of moldboard plow for 1466
Posted by Larry B 1486 on May 16, 2010 at 19:22:21 from (67.142.161.36):
In Reply to: Size of moldboard plow for 1466 posted by Yellott Canby on May 16, 2010 at 18:51:24:
As DeltaRed said depends on soil type and what part of the country you live in, flat ground or hilly. In clay soil, 5-18's would be a good match. Thoes 1466's have the power probley to pull 6 or 7 bottom in sandy soil if you can get the traction. I own two 1466's and only plowed one time with the one 1466, I only had a JD 3pt 4-16 plow and it walked away with it in high range first gear. That was in fescue sod ground in early sept.
