Re: Rocker questions 49 M
Posted by Janicholson on May 17, 2010 at 07:11:31 from (64.61.211.141):
In Reply to: Rocker questions 49 M posted by DM IOWA on May 17, 2010 at 05:08:12:
The rocker face is not flat it is contoured to match the rub of the tip on the valve butt. The grinding process used to make them correct is only found an a valve machine (Souix, and other brands work well. The oil tube does come out with the shaft. I do not know the torque. Jim
