Re: Need a 450 expert
Posted by Nebraska Kirk on May 17, 2010 at 07:17:36 from (207.91.4.226):
In Reply to: Need a 450 expert posted by D Slater on May 16, 2010 at 16:49:42:
u00bgg2 said: (quoted from post at 17:49:42 05/16/10) Hello there, I have lurking on the site for some time reading and educating myself and am now at the point where I need to reach out to the group.
I came into the possession of 58 450 tractor in Jan of this year. It was my grandfathers tractor that he bought nearly new and kept until his passing in 2008. The tractor had last been started in 2004-05 time frame, with the motor locking up after this point. I did everything I know to get the motor un stuck but it was not happening so I ended up tearing it down. Once the head was off I found the all four pistons were stuck, two of them very badly. I got the two easy ones out and the other two eventually came out taking the liners with them.
I now have the all the pistons out, and the liners reinstalled. The pistons are in decent shape but the rings are bonded into the groves with corrosion. I have gotten the rings off of two pistons so far but it is not looking good for the other two.
Sorry for all the wind above, my questions are as follows:
-What or where is a good source to purchase pistons and or just piston rings? I find all kinds of rebuild kits but non where I can by engine component parts.
-Second question is in regard to ring size. The motor is a C281 but there are many different piston and ring options based on the size of the bore. I have measured the bores and they appear to be standard 4.125 but I am not generally seeing this in the listings.
-Lastly how sensitive is this motor? I am not and engine rebuild expert but I think I am competent to get the job done. If this is a very touch motor where every torque spec and clearance has to be exact then this may be out of my league.
Thank you,
Brian
You can buy individual pistons from A&I through a dealer. I use rustyfarmall.com
If you are interested, I have 4 brand new 4.125" 450 pistons that I would sell to you.
The engine is tough but not bullet proof and attention must be paid to details like torque specs, piston ring clearance, bearing clearance, proper orintation of the pistons and con rods.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
