Re: Dead 6V Battery on H
Posted by Dan 130 on May 30, 2000 at 05:24:30 from (216.90.48.4):
In Reply to: Dead 6V Battery on H posted by Greg on May 29, 2000 at 22:11:38:
Are you sure the battery is in fact charging up completely ? It may appear your battery is draining when actually it only had a surface charge or no charge at all. With tractor shut off, do you get any spark from the battery if you disconnect the cable and touch it to the terminal ? Be careful doinging that , but, it will let you know if something is pulling your batt. down. Look for even a small spark as you rub the cable on the battery post. If you do, then start disconnecting suspected componants ( regulator etc) one at a time until no spark. Good Luck
Post A Followup
: Re: Re: Dead 6V Battery on H
