Posted by Chas Weller on May 17, 2010 at 17:10:57 from (71.245.59.83):
Originally posted 5/6 (thanks for advice) tractor stalled after working about 15 to 20 minutes. Will now not start, tries to run but fires out exhaust pipe? Have had tractor about 10 months normally easy to start as long as you catch it when it first fires; otherwise seems to flood? Replaced plugs, points, condenser, cap and rotor all appeared old. Spark at all four plugs. Please help with suggestions? since then compression is (1)70,(2)80,(3)85,(4)90 - not great but still should run? will not start fires out both exhaust and intake - Have spark, Air, Fuel. I think that indeed the cam/timing gears have broken or slipped? I have removed the valve cover and all valves are opening and closing - how is this possible if the timing gears are broken, since there is no chain is it possible for the gears to jump? Not break but jump teeth?
Many thanks to all for discussion, help, advice and pictures.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
