Re: 656 hydr pump
Posted by Don656 on May 18, 2010 at 08:15:51 from (24.210.220.234):
In Reply to: 656 hydr pump posted by bobia7 on May 17, 2010 at 15:37:52:
What problem are you having? I haven't changed the pump, but on my 656 I lost all hydraulic function. There is a hollow internal splined hub that drives the hydraulic pump from the clutch pressure plate (on my gear-drive 656). This hub is riveted on and mine sheared the rivets. There is a clutch inspection plate, take that off and see if there are any broken parts in there. This may not be the cause,but it is an easy thing to check.
