Re: Special Engine Paint?
Posted by sammy the RED on May 30, 2000 at 07:03:50 from (209.130.145.107):
In Reply to: Special Engine Paint? posted by Lynn Hait on May 30, 2000 at 06:07:45:
I did not know that Central Tractor carried IH 2150, thought you could only get it from your Case/IH dealer. What primer is he going to use ? You should use same brand for the base coat and top coat. I use the primer and red top coat [IH 2150] from my Case/IH dealer. Never have used any special engine paint, just IH 2150 from my Case/IH dealer. Hardener will add gloss but the paint may chip easier if this is a work tractor.
Post A Followup
: Re: Re: Special Engine Paint?
