Posted by Donald in MN on May 18, 2010 at 19:59:23 from (64.12.116.73):
In Reply to: engine swap posted by caterpillar guy on May 14, 2010 at 20:21:55:
My dad has an 856 and a 1086 with a dt414 in it .The 856 has the fuel pump on the right side and the 1086 has the fuel pump on the left the 1086 uses a cable for a throttle but you may be able to get a throttle linkage off a 966 or 1066 and adapt it to run on the left side . Also the lower radiator hose is on the right for the dt414 and the left for 856. You might be able to get a radiator from a 966 or 1066 to use. the 86 series had the filler cap off set to the right, idont remember if the 66 series had an off set filler cap or center filler. If you had a cheap rad. man maybe he could switch tanks or just drill a hole in the hood. The oil sump holds 4 gallons on the 856 and the 1086 holds 5 gallons so i dont know if the pan will interfer with the front steering linkage . hope this helps Donald
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
