Re: C135 Engine Swap
Posted by ShaggyM on May 19, 2010 at 05:40:00 from (173.24.164.128):
In Reply to: C135 Engine Swap posted by Eric P on May 18, 2010 at 11:14:13:
I have a Super C with a 153 in it and i have helped a few others put them in. Its not to bad.
We had to cut about 1 1/4 off the drive shaft and you need to come up with a bearing the will press into the fly wheel to be used as a pilot bearing. I used a 140 water neck (upper and lower)or you could cut the loop that holds the fan on the stock upper water neck and you wouldn't need to change the radiator.
And you'l need to rejet the stock C carb a little.
