Posted by Bob WA on May 19, 2010 at 06:18:08 from (99.196.224.56):
In Reply to: Farmall Diesel 656 posted by John Athey on May 18, 2010 at 11:23:52:
Clean engine well change filters in a clean invironment.bleed filters and check for good fuel flow.Bleed injecter pump next using primary hand pump. or you can pressurize the the fuel tank using very low pressure. Bleed injecters next by opening high pressure lines at injectors one half turn and cranking engine. let the starter reest between short intervals of cranking.If still no success check return lines back to tank.They shoud not be plugged.A clear fuel line can be installed before main pump to check for air leaks into system.Again cleanliness is extremely important.The fuel filters are the last line of defence against dirt damage in the close torerence fit of your injecter pump and injecters.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
