Re: Hyd oil in crankcase
Posted by Janicholson on May 19, 2010 at 07:16:25 from (199.17.6.222):
In Reply to: Hyd oil in crankcase posted by Gary Vestal on May 19, 2010 at 06:43:42:
Incorrect assembly of some pumps can cause the pressure relief to be ported to the wrong side. This allows output pressure to be put on the O ring. It is not designed to be put under pressure, only the supply side gravity (maybe two or three PSI at most). Other than that a wron Oring can be a leaker, Try teflon based high performance rings from a hydraulic shop as a last resort. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
