Re: Farmall M Front Wheel Bolts
Posted by Dave_Id on May 19, 2010 at 08:10:33 from (63.246.177.253):
In Reply to: Farmall M Front Wheel Bolts posted by Jim R on May 19, 2010 at 05:55:40:
McMaster Carr is a good supplier of square head bolts. I don't believe originally they were ever better than Class 2 from the looks of most of those that are pulled out of early M's and H's. Lockwashers are a must. The problem with using hex head is that they will spin much easier on you if they are in for a long time compared to square head bolts. I'm talking here about the early Farmalls that used the clamps instead of the later version wheels
