Re: Farmall M Front Wheel Bolts
Posted by gene bender on May 19, 2010 at 10:08:58 from (67.55.226.67):
In Reply to: Farmall M Front Wheel Bolts posted by Jim R on May 19, 2010 at 05:55:40:
You can use fine thread hex head and losk washers and a little lube. I like to use the impact wrench going around a couple times from one to the next till the socket just dont move. It sure doesent hurt to check from time to time as part of regular upkeep.
