Re: farmall f20 valve stuck
Posted by oldiron29 on May 20, 2010 at 09:30:44 from (74.88.10.162):
In Reply to: farmall f20 valve stuck posted by kelby on May 20, 2010 at 08:22:40:
kelby, I tap the vavles with a block of wood lightly and spray with PB most time I can get them loose and you have to work them back in.
every day you run the tractor you should oil the head. Check you level and drain if needed.
Oldiron29
