Re: Farmall M Front Wheel Bolts
Posted by Mike Farmer on May 20, 2010 at 09:32:15 from (86.29.32.60):
In Reply to: Farmall M Front Wheel Bolts posted by Jim R on May 19, 2010 at 05:55:40:
Depends how badly you need them. I would make some. Buy some long bolts of the correct thread and diameter-Cut the heads off-make head blanks by cutting some square steel of the required size-drill and tap- screw head on to bolt about 3/4 of the threaded part of the blank-weld or braze the head onto the bolt-grind it to look good-cut to required length.It works. I will try to find sme pics of the ones I made for my M. MTF
