Remove the bolts from the front end that bolts to the pan. Remove the bolts in the back of the pan that bolt to the clutch housing. In the back of the pan there are hidden bolts you will have to use and extension to remove them. If i remember there are 4 across the back in the webbing of the pan. I have always used a little floor jack under the pan to let it down easy the pan is a little on the heavy side. When you install the new gasket make sure you also replace the two little black wedges that go at the back of the engine. When you remove the old pan gasket look for them at the back of the engine. Make sure you install them back in with some permatex or you will have a big leak.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
