Re: farmall f20 valve stuck
Posted by 36F30 on May 20, 2010 at 10:25:46 from (65.168.253.84):
In Reply to: farmall f20 valve stuck posted by kelby on May 20, 2010 at 08:22:40:
Don't pry on them you'll bend them. I set the head on edge and drive the stem in with a hammer, then spray the stem with PB and lightly tap them back to the seat. I use a wood dowel on the valve end. After several times even the worst ones come out for me.
Oil the top end every ten hours running time and it should always be the first thing you do on startup procedure.
This post was edited by 36F30 at 10:28:25 05/20/10.
