Re: Farmall H ...Lead additive???
Posted by John T on May 20, 2010 at 12:17:49 from (66.244.97.31):
In Reply to: Farmall H ...Lead additive??? posted by muppet on May 20, 2010 at 11:44:46:
I dont forsee it will cause any obeservable problem in the next few years in that relatively low hour use, low RPM, low compression engine with relativley low strength valve springs lol
Nowwwwwwww if it were a high performance engine running under high compression at extreme high RPM with heavy duty valve springs and a radical cam grind and it DID NOT have hardened valves n seats, wellllllllll perhaps then Id use it.
Its your tractor and your money so its your call, however.
John T
