Re: HIGH CROP 140
Posted by gene bender on May 20, 2010 at 12:34:26 from (67.55.226.67):
In Reply to: HIGH CROP 140 posted by RICHARD J. HEATH on May 20, 2010 at 10:59:03:
Asuming its ctacked behind the carb where they crack gring it clean and fiberglass or you can use atha rubber cement used when installing windshields or JB WELD can work its worth a try i have one thats been running for many yrs now fixed with the rubber cement.Now if you are getting coolant in the oil that probably means the bolck has cracked at the topbetween the bores and thats another thing. I would patch the block outside then use the tractor and see what happens.
