Re: Put a loader on my H - it wont lift?
Posted by soybeanjoe on May 20, 2010 at 16:57:43 from (66.213.171.108):
In Reply to: Re: Put a loader on my H - it wont lift? posted by Allan In NE on May 20, 2010 at 15:53:31:
I've seen lot's of Hs with loaders over the years that didn't have extra hyd tanks & worked fine. Growing up we had a '41 H that had a Schwartz dual cylinder cable lift loader. Tracor was settup with live hyds & used the old belly pump for a reservoir, internal pump still inside. We feed 3-400 head of feeder calves daily from the time the tractor was new til the early '60s using that H & loader to load silage from a bunk into chuckwagons. Also loaded lime, fertilizer & gravel with it into IH KB6 truck with Gallion gravel bed. Tractor & loader was pretty much wore out when I got rid of it in the early '70s but before getting rid of it I took the live pump & belly pump off and swapped into another H that didn't have live hyds. That old wore out pump was able to lift a 15' Brillion cultimulcher I put together in the early '80s
