Re: farmall f20 valve stuck
Posted by Nebraska Cowman on May 20, 2010 at 18:17:05 from (66.252.122.171):
In Reply to: farmall f20 valve stuck posted by kelby on May 20, 2010 at 08:22:40:
I have. If they are not stuck solid. If you can tap them down with a light hammer and then pop them back up with a tire iron. But if they are suck tighter than that you will have to take the head off. Sorry.
