Stage II Super M Live Hydraulics
Posted by Andrew Z on May 21, 2010 at 06:28:44 from (64.252.148.52):
I went to go use my Super MD with a friends NH 474? haybine the yesterday. I hooked up the remote and when i pulled back the lever on the side of the hydraulic res it would raise it just fine, but when i released it the would not hold it up. Are there check valves inside the res that are possible stuck or do i need to run a spool valve of some sort with this system as my check point?
thanks for the help
Andrew
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
