Posted by D Slater on May 21, 2010 at 13:07:35 from (72.65.132.215):
In Reply to: W450 D TACK drive gear posted by Terry Harnett on May 20, 2010 at 23:04:17:
If the W450 D is serial # 1669 or higher, or was changed over sometime to the last design tach drive, the gear is still obtainable. IH changed the drive 2 times after first design. Last type is identified by a smooth gear housing with no adjustment notches. Housing has a little retainer that goes in a slot to keep gear from going forward into harder mesh with the distributor drive gear. IH used to sell the housing, retainer and gear as a package to replace early type drives. Package NLA, you can still get the gear, part # 369695 R91. If you're good at modification the gear can be made to work in the old housings. Housing bore needs enlarged unless worn bad or shaft made a little smaller and sometimes end made a hair shorter. Works best in the correct housing though.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
Latest Ad:
[More Ads]
