Re: super chief or not?
Posted by soybeanjoe on May 21, 2010 at 13:22:39 from (66.213.171.108):
In Reply to: Re: super chief or not? posted by farmallboy15 on May 21, 2010 at 12:34:36:
Easiest way to measure from the arm that holds the coulter for the second or 3rd bottom to the same arm in front of it. Looks like on that plow however that arm may not extend straight forward far enough. If that"s the case draw a line on the ground straight forward from the second share, then measure from that line at a 90º angle to the tip of the share of the front bottom. That distance should equal the width of the bottom.
