Re: Super A bolster threads stripped.
Posted by Brian2 on May 21, 2010 at 18:52:40 from (74.13.124.74):
In Reply to: Re: Super A bolster threads stripped. posted by Janicholson on May 21, 2010 at 16:46:32:
thanks for the advice Jim, I have the manual, and you are correct about the differential. One question, what is the difference between a heli coil and the thread insert you suggested? Can I drill out the hole using a hand drill, or will I need to rent a magnetic base type to ensure I have it perfectly square?
Thanks again.
