Posted by Farmerhr on May 21, 2010 at 20:27:02 from (64.12.116.73):
Does any know how IHC assembled the king pin to the wheel axle on a wide front M ?
Mine looks like the king pin was a separate piece that was assembled to the wheel spindle. It looks like the wheel spindle was machined with a thru hole and then the king pin was put into the machined hole. The king pin has a clearly visable center in the bottom. The king pin does not go quite to the bottom of the hole machined in the wheel spindle and you can see a machined surface that the king pin does not cover up. No pins, welds, or theads are evident in the joint between the two parts. Is it just a heavy press fit ? Is the king pin a cylindrical surface in the joint ?
The top of my king pin has been ruined. I would like to replace or repair the king pin.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
