Posted by jonathan mirgon on May 22, 2010 at 04:20:49 from (99.34.123.161):
I overhauled my s-c engine , and put in a new clutch but reused the pressure plate. After reassembling the clutch does not disengage all of the way causing grinding when trying to go into any gear. I adjusted the pressure plate as far as it would go through the hand hole cover, And it is improved but still not right. I plan on having flywheel machined this time and I have the new pressure plate.Question is do I need to check the new pressure plate adjustment , Or is it safe to assume they are adjusted correctly out of the box ? I bought the pressure plate from this site. Clutch was never a problem before, But I assume that the problem was due to the new clutch lining being much thicker than the old worn out one. Thanks in advance for your help !
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
