Re: Farmall H alternator
Posted by Dave_Id on May 22, 2010 at 05:34:21 from (63.246.177.253):
In Reply to: Farmall H alternator posted by jbradley on May 22, 2010 at 04:27:02:
I used a GM alternator, I had to grind a little off the fins, and off the lip of the valve cover, but I did it... I also have a picture of an H setup with a homemade bracket that brought the alternator lower. I can email that if you are interested. Why do you want to switch?... if it turns over slow with 6 volt, try heavier battery cables.
