Re: Super A flooding as soon as i turn on tank valve
Posted by Bob on May 22, 2010 at 10:18:24 from (69.178.228.68):
In Reply to: Super A flooding as soon as i turn on tank valve posted by ctallen2010 on May 22, 2010 at 10:10:31:
Is the inlet needle seat #%^& TIGHT into the carb body with it's gasket in place?
Is the float "heavy"?
Just because the float is rattling around in there doesn't mean it isn't still bent. It MAY be making contact with the carb body somewhere just as it begins to push the needle closed against the seat.
If there's two "floats" on a forked arm are they at the same height?
