Re: engine runs away on Super A
Posted by Bob on May 22, 2010 at 10:47:29 from (69.178.228.68):
In Reply to: engine runs away on Super A posted by ctallen2010 on May 22, 2010 at 10:14:17:
Sounds like something is stuck or the linkage is binding or has been tweaked way out of adjustment.
Try this first...
With the engine "OFF", set the throttle a little above idle and try moving the linkage between the governor and the carb. It should be free to move, with little resistance, through the complete range of motion of the throttle butterfly shaft.
